Results 1 to 7 of 7
Thread: Text im model space not displaying correctly in paper spsce
    2019-03
    32
    Default Text im model space not displaying correctly in paper spsce
    I'm using a plug in to name and count objects that I'm detailing. It labels them all in model space I am then inserting title blocks in paper space and dimensioning them.
    When I started all of the text in model space was printing nicely in paper space but somewhere it changed and now the text is printing very bold and is almost unreadable.
    As far as I can tell the text properties are the same for all of the printing. I have included 2 PDF drawings for comparison.
    Does anyone have a suggestion as to how I can fix it?
    Turlock, CA
    6,420
    Default Re: Text im model space not displaying correctly in paper spsce
    Can you post the dwg's so that we can look at the settings? Are they using the same ctb? You might want to post those too.
    C:> ED WORKING....
    LinkedIn
    2019-03
    32
    The drawing is too big to attach but here is a wblock of a couple of the individual parts. The text appears to be OK now in this wblocked drawing so its something in my original drawing.
    They are both in the same drawing so all plot settings are the same.
    - - - Updated - - -
    This didn't attach properly
    2019-03
    32
    Here is another drawing. I copied a viewport from the drawing into the wblock and the print view issue returned.
    Its the top drawing in paperspace.
    2019-03
    32
    Finally worked it out.
    Its an issue with printing in hidden view style
    2005-06
    in the upper right corner
    3,507
    Quote Originally Posted by bruce13557 View Post
    Thanks for letting us know what the issue was, it helps others looking for similar solutions down the road.
    2019-03
    32
    I finally found the issue that was causing the problem. I turned off silhouette edges.
  1. 2004: Paper space text behind model space solid hatch while viewing
    By david1030 in forum AutoCAD General
    Last Post: 2017-06-05, 09:12 PM
  2. 2011: Text shows up in Model Space but not Paper Space
    By rbelling974531 in forum AutoCAD General
    Last Post: 2015-12-03, 12:22 PM
  3. Replies: 2
    Last Post: 2010-03-23, 07:22 PM
