Thread: Mtext line thickness
    2019-03
    32
    Default Mtext line thickness
    Is it possible to change the line thickness of text?
    2005-06
    in the upper right corner
    3,507
    Default Re: Mtext line thickness
    Quote Originally Posted by bruce13557 View Post
    Well if you mean PLOT bolder, yes but it depends on the font(s)
    Typically "True Type" Fonts (TTF) you can't really make them plot bolder, you need to pick a bolder font.
    But if you're using an AutoCAD "SHX" font like Romans.shx, and you're using plot styles, you put the text on a bolder layer or assign a color that will plot bolder, based on your plot style.
    (see screen shot)
    You can even assign a different color to the some of the text within the MTEXT, but that is overriding the MTEXT properties and is sometimes frowned upon.
  1. Multi line Mtext to Single line Mtext
    By csiress.154683 in forum AutoLISP
    Last Post: 2013-06-12, 02:21 PM
  2. Replies: 8
    Last Post: 2007-03-12, 02:18 AM
  3. Thickness vs Foundation Thickness
    By eric.anastas in forum Revit Architecture - General
    Last Post: 2006-11-10, 08:12 PM
  4. Hatch Pattern Line Thickness
    By designer56644 in forum Revit Architecture - General
    Last Post: 2004-04-01, 11:15 PM
  5. Leader Line thickness?
    By Kroke in forum Revit Architecture - General
    Last Post: 2004-02-12, 11:31 PM
