Thread: regular expression in formula
    All AUGI, all the time Ning Zhou's Avatar
    2006-08
    632
    Default regular expression in formula
    i assume it's no doable to use regular expression in formula, isn't it? what i'm thinking is to get central file name and user name from local file name which is available in "File Path" OOTB paremeter in titleblock, any solution except coding (API, Dynamo)?
    2002-09
    Madison, WI
    5,651
    Default Re: regular expression in formula
    What are you trying to accomplish?
    You just want a label to return the central file name and path vs the local file name and path?
    Dave Peterson
    BIM Coordinator
    Acad - 2019 - Revit 2020 w/ BIM 360 - Navisworks - 3ds 2020 - Ensacpe - Lumion - Win 7 64 - i7-8086K 4.0GHz 32GB Ram - Nvidia Quadro P2000
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2006-08
    632
    yes Dave, i can get both central file name and user name from local file name which is available OOTB, only need a bit of string operation which i assume not doable unless coding
  1. 2013: How to use this Formula,"Formula That Returns Strings"?
    By mike99 in forum Revit Architecture - General
    Last Post: 2013-01-09, 06:28 AM
  2. Problem with Text Size, Regular vs Bold
    By Scott D Davis in forum Revit Architecture - General
    Last Post: 2007-11-29, 11:32 PM
  3. Spot fixture vs regular fixture
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2005-02-20, 03:45 AM
  4. Tool Palettes different in Map that regular Acad
    By gstankus in forum AutoCAD Customization
    Last Post: 2004-06-10, 10:47 PM
