Thread: New Times Romans not printing correctly
    2014-08
    448
    Default New Times Romans not printing correctly
    Hi
    I have one user that seems to have a problem I never heard of and have researched without finding the answer.
    One sheet prints the text fine, the next sheet prints the dimensions with outlines of the text no fill.
    I this is happening on one sheet. I have check and verified that both sheets are using the same dimstyle with no overrides on the text style.
    I have checked the textfill variable and the textqlty variable check styles for text dialog totally baffled at this point.
    Turlock, CA
    6,421
    Default Re: New Times Romans not printing correctly
    Can you post a sample of the dwg?
    C:> ED WORKING....
    LinkedIn
    Cairo - no, not Illinois
    5,069
    For TTF font problems, one of the things I check is the Z value used by the text or dim object. enshure that it is actually at 0
    2014-08
    448
    Hi
    Found a solution; changed the display mode from 2d wireframe to as displayed then back everything appeared normal and plotted correctly
  1. RomanS vs romans.shx
    By darthyoga in forum AutoCAD Tables
    Last Post: 2024-01-05, 05:55 PM
  2. RomanS Bold Dim Style...
    By aaronrumple in forum Revit Architecture - General
    Last Post: 2017-09-03, 02:54 AM
  3. All Text plotting Romans (not good)
    By JeffClark in forum AutoCAD Plotting
    Last Post: 2010-01-08, 07:05 PM
  4. Global Change all Text Styles to Romans font
    By f.tagle in forum AutoLISP
    Last Post: 2009-04-29, 05:04 AM
  5. Romans font, N's printing as rectangles
    By Jettero2112 in forum AutoCAD General
    Last Post: 2004-09-10, 12:29 PM
Tags for this Thread
