Thread: Filled Region Circle Patterns
    2020-03
    2
    Default Filled Region Circle Patterns
    Hi Guys,
    Hoping you can help somewhere out there in the digisphere.
    I have to document balls in a floor slab system and trying to develop fill patterns for:
    180dia circles @ 220mm spacings,
    225dia circles @ 260mm spacings
    270dia circles @ 300mm spacings
    Does Revit still have the same restrictions with circle hatch as described elsewhere? Is there a way to create or customize existing?
    image of system:
    2020-03
    2
    Default Re: Filled Region Circle Patterns
    Image of system shows the balls in a grid formation. Bubbledeck Floor System
    2005-06
    in the upper right corner
    3,508
    I don't know for sure but would an array work?
    Create one and array it?
    You're looking to do a 2D annotation filled region right?
    I played with it a bit, it's doable, you need look into the array options.
    (see attached image as an example)
  1. Dimension from face of circle to face of circle?
    By ljlange in forum Revit Architecture - General
    Last Post: 2009-10-18, 04:45 PM
  2. Distance from circle to circle
    By Brian.164262 in forum AutoLISP
    Last Post: 2008-04-24, 05:31 PM
  3. Allow rotation of Filled Region patterns.
    Last Post: 2007-12-21, 02:29 PM
  4. Filled region to masking region?
    Last Post: 2007-08-15, 01:56 PM
  5. Circle Polyline (ie Circle with Width)
    By johan d in forum AutoCAD General
    Last Post: 2006-02-03, 11:16 PM
Tags for this Thread
