Thread: Can I offset structural footings from center?
    I could stop if I wanted to vanderloo5's Avatar
    2002-03
    Sacramento Ca.
    411
    Default Can I offset structural footings from center?
    By default, when adding bearing footings, they center on the concrete wall above which is not the typical preference in the field. Is there a way to offset my bearing footings from center to favor the inside of the foundation?
    Thank You
    Phil Vanderloo,
    LEED AP, General Contractor
    Hiline Builders Inc.
    in the upper right corner
    3,239
    Default Re: Can I offset structural footings from center?
    Quote Originally Posted by vanderloo5 View Post
    Thank You
    Yes you can, you tweak the "Eccentricity", normally it's zero when centered, but you add + or - values and it offsets the center of the wall.
    Ted
    Windows 10
    2002-03
    Sacramento Ca.
    411
    Thank You tedg. That's what I needed.
    Phil Vanderloo,
    2002-09
    Madison, WI
    5,662
    You can also look at a retaining wall footing where you can define the toe and the heel.
    Just another way to think about it offset footing.
    Dave Peterson
    BIM Coordinator
    Acad - 2019 - Revit 2020 w/ BIM 360 - Navisworks - 3ds 2020 - Ensacpe - Lumion - Win 7 64 - i7-8086K 4.0GHz 32GB Ram - Nvidia Quadro P2000
  1. Replies: 0
    Last Post: 2014-12-15, 08:28 AM
  2. Replies: 0
    Last Post: 2014-12-13, 09:25 PM
  3. Attaching Structural Columns to Footings
    By Heitman Architects in forum Revit Architecture - General
    Last Post: 2006-10-02, 03:46 PM
  4. Structural/raft footings
    By Adam Mac in forum Revit Architecture - General
    Last Post: 2006-09-20, 04:03 AM
  5. Can wall footings wrap?
    By jrichardson in forum Revit Structure - General
    Last Post: 2005-11-03, 12:21 AM
