I have used LAYTRANS in the past, and for the first time I have come up with this issue. I run the translator, load my DWS file, map the offending layers to the correct name (hit "Map") and check the layer translation mappings in the lower pane and they are correct. I then hit "Translate". Checking the log shows that the layers did map, but when I check the drawing itself the layers are still there.
Anyone have any thoughts?
Thanks
