Thread: Description Keys
    2004-11
    20
    Question Description Keys
    I have a Description Key Set that I added a few new description keys parameters. The first new parameter worked perfectly, the designated points changed to the correct style/label/layer. Now the rest of the new ones I'm adding are not being applied. I've saved the drawing, closed down to program, everything I can think of to refresh the drawing.
    There is only one Description Key Set in the drawing. I've tried adding another DKS with these rogue point descriptions; that did not work. I've been searching for a location where the DKS is named as a default.
    Earth
    9,805
    Default Re: Description Keys
    The codes are case sensitive.
    R.K. McSwain | CAD Panacea |
    2003-07
    561
    I do have the missing link a import description key sets, you can add or create a complete new one. It uses excel as the source as much easier to copy lines etc
    You can export a key set to excel but there is no default import.
    Post here and can provide more information.
  1. Is there a way to change your quick keys, or short cut keys?
    By smooth shoes in forum AutoCAD General
    Last Post: 2006-11-16, 12:22 AM
