Thread: Convertpstyle
    2009-11
    Raleigh, NC
    944
    Default Convertpstyle
    Convertpstyle from ctb to stb a few years ago was not an issue. Is the a converter agent or file that I need?
    Turlock, CA
    6,420
    Default Re: Convertpstyle
    You're not very clear on what issue you're having. btw, it CONVERTPSTYLES with an S. Maybe that's your issue?
    C:> ED WORKING....
    LinkedIn
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    For using CONVERTPSTYLES you need a CTB plotstyle along with a matching STB plotstyle to convert to.
    Many years ago I came up the attached plotstyles to make it easier.
    Later I added a lisp function to quickly convert outside drawings to FDOT.stb from Florida Dept. Of Transportation
    ; Set drawing settings to FDOT.stb
    ; (load "FDOT255.lsp") FDOT255
    ; ^P(or C:FDOT255(load "FDOT255.lsp"));FDOT255
    (defun c:FDOT255 ()
     (if(=(getvar "PStyleMode") 1)(command "_convertpstyles" "acad - Convert.stb"))
    ; (cond(=(getvar "DwgTitled")0)(alert "Drawing must be saved first!")(exit))
     (vla-put-StyleSheet
        (vla-get-ActiveLayout (vla-get-ActiveDocument (vlax-get-acad-object)))
        "FDOT.stb"
      (setq layers (vla-get-layers(vla-get-ActiveDocument (vlax-get-acad-object))))
      (vlax-for l layers
        (progn
     	(cond
       	  ((equal (vla-get-color l) 8)(setvar "CPLOTSTYLE" "125")(vla-put-plotstylename l "125"))
       	  ((equal (vla-get-color l) 9)(setvar "CPLOTSTYLE" "125")(vla-put-plotstylename l "125"))
       	  ((equal (vla-get-color l) 250)(setvar "CPLOTSTYLE" "125")(vla-put-plotstylename l "125"))
       	  ((equal (vla-get-color l) 251)(setvar "CPLOTSTYLE" "125")(vla-put-plotstylename l "125"))
       	  ((equal (vla-get-color l) 252)(setvar "CPLOTSTYLE" "125")(vla-put-plotstylename l "125"))
       	  ((equal (vla-get-color l) 253)(setvar "CPLOTSTYLE" "125")(vla-put-plotstylename l "125"))
       	  ((equal (vla-get-color l) 254)(setvar "CPLOTSTYLE" "125")(vla-put-plotstylename l "125"))
       	  ((equal (vla-get-color l) 255)(setvar "CPLOTSTYLE" "Normal")(vla-put-plotstylename l "Normal"))
       	  (T(setvar "CPLOTSTYLE" "255")(vla-put-plotstylename l "255"))
      (setvar "CPLOTSTYLE" "ByLayer")
      (princ)
    Hope that helps.
