Thread: Revision call out numbers in triangles as a standard block
    2016-04
    California
    150
    Default Revision call out numbers in triangles as a standard block
    Hello all,
    Does anyone know of a standard revision number block that is used as a revision call out note? The type that is usually used is a number surrounded by a triangle. I looked in the pallets and saw nothing.
    TT
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: Revision call out numbers in triangles as a standard block
    That is typically a three sided polygon with an attribute created with the attdef command placed in the approximate center of the triangle. This could easily be combined using the block command.
    2011-10
    Norfolk England
    57
    Hi
    Try these callout blocks ....... among them is a standard Revsion
    They are in Millimeters, so just scale to 0.0394 to give Inches.
    Not the best solution as the text size is 5mm or 3mm, so using Imperial units it would probably be ¼" and 3/16" if the blocks were produced from scratch using Imperial units.
    Hope you find them useful!
    Geoff
    Another way to convert to Imperial units is insert the whole drawing as a block using Insert Block and checking the Explode box and putting 0.0394 into the Scale box on the dialog box (see Attached Image)
  1. 2013: Revision Cloud Triangles
    By rdooley944157 in forum Revit MEP - General
    Last Post: 2012-09-14, 06:52 PM
  2. Ability to have letters as well as numbers in as revision sequence numbers
    Last Post: 2007-10-01, 01:07 PM
  3. Translate nVidia installer numbers to driver numbers
    By Andre Baros in forum Revit - Hardware & Operating Systems
    Last Post: 2007-02-14, 05:08 PM
  4. linked room numbers & door numbers
    By tim.101799 in forum Revit Architecture - Wish List
    Last Post: 2006-07-18, 08:44 PM
  5. Call out sections as numbers or letters?
    By crohloff.72988 in forum CAD Standards
    Last Post: 2006-06-26, 06:44 PM
Tags for this Thread
