Thread: Zoom to object in XREF
    2015-06
    Default Zoom to object in XREF
    Hey everybody, new user, first post here.
    Is there anyway to select a single object in an XREF, without selecting the entire XREF?
    In this case, this is specifically to use the zoom to object command, not to edit anything.
    9,800
    Default Re: Zoom to object in XREF
    I have not tested it, but thinking out loud, I'm thinking you could use something like this to grab the nested entity:
    (setq x (car (nentsel "\nSelect an object ")))
    Then find the bounding box for that object and zoom to those coordinates.
    2015-06
    Thanks for the recommendation. That makes sense and looks like it would work. I’ve never written a lisp, guess its time to figure that out. I’ve been putting it off too long...
    I’ll see what I can come up with.
    9,800
    @zebchamlee -- here is a quick and dirty version. No error checking included.
    (defun c:foo ( / x obj minP maxP)
      (setq obj (vlax-ename->vla-object x))
      (vla-GetBoundingBox obj 'minP 'maxP)
      (command "._zoom" "_W"
        (vlax-safearray->list minP)
        (vlax-safearray->list maxP)
    2020-11
    Either select the block ==> right click ==> Block-Editor ... and do your modifications in that space ... or
    run command _EXPLODE to make all objects within the block to separate objects.
    Cairo - no, not Illinois
    4,859
    just what does that have to do with the original question?????
  1. 2018: Object Selection in 3D view changes view focus, View zoom. Zoom level.
    By arch_kashif in forum Revit - Platform
    Last Post: 2019-11-23, 01:59 PM
  2. 2008 SCALE 1:100 xref xref xref xref- scale list issues
    By Apsis0215 in forum AutoCAD Customization
    Last Post: 2008-11-21, 08:17 PM
  3. Zoom, zoom, zoom...
    By Steve_Bennett in forum AutoCAD General
    Last Post: 2005-06-15, 02:59 PM
  4. ucsfollow zoom rotates view without zoom extents
    By dbroad in forum AutoCAD Wish List
    Last Post: 2004-10-05, 06:21 PM
