Thread: Stepped Offset Feature Lines
    2009-11
    Raleigh, NC
    944
    Default Stepped Offset Feature Lines
    Can I chang a setting too step offset feature lines so the vertexes in original Feature Line will not create arcs?
    2015-12
    Arizona
    2,478
    Default Re: Stepped Offset Feature Lines
    OFFSETGAPTYPE (System Variable) is your friend on this one
    Controls how potential gaps between segments are treated when polylines are offset.
    Type: Integer
    Saved in: Registry
    Initial value: 0
    Value
    Description
    Extends line segments to their projected intersections.
    Fillets line segments at their projected intersections. The radius of each arc segment is equal to the offset distance.
    2
    Chamfers line segments at their projected intersections. The perpendicular distance from each chamfer to its corresponding vertex on the original object is equal to the offset distance.
  1. Dynamically link feature lines created via stepped offset.
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2015-12-05, 07:39 PM
  2. Replies: 5
    Last Post: 2014-02-24, 03:15 PM
  3. Replies: 0
    Last Post: 2010-09-21, 02:11 PM
  4. Why does Stepped Offset not work on only one of my feature lines?
    By m.vanitallie in forum AutoCAD Civil 3D - Grading
    Last Post: 2008-06-06, 05:39 PM
  5. Stepped Walls w/ Stepped Footings
    By BomberAIA in forum Revit Architecture - General
    Last Post: 2006-09-12, 05:14 PM
