Thread: Existing Polylines for a Surface
    Raleigh, NC
    937
    Default Existing Polylines for a Surface
    I have a file of contours (2d polyines). I attached an image to show the high # of vertices that I don't want to slow my grading file down.
    What is a method I could use to create an existing surface from this data but nit require so much memory to slow the files down?
    9,803
    Default Re: Existing Polylines for a Surface
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    RK's suggestion will reduce the data points and likewise the surface size will be reduced, which may be all you need. If you want to reduce the actual number of vertices in the polylines and make the drawing smaller use the WEEDFEATURES command.
    9,803
    Thanks @jpaulsen - I went too fast and didn't read the content of the URL I posted. I thought I was posting the link you did.
    Nice save.
  1. Polylines with arcs to polylines with segments
    By randyspear in forum AutoCAD General
    Last Post: 2009-04-15, 06:22 PM
  2. Replies: 7
    Last Post: 2008-02-22, 04:13 PM
  3. How to change LW PolyLines to 2D PolyLines
    By Lions60 in forum AutoLISP
    Last Post: 2007-07-13, 05:58 PM
  4. How to convert 3D Polylines to 2D Polylines
    By GreyHippo in forum AutoLISP
    Last Post: 2007-01-04, 05:32 PM
  5. AutoCAD polylines to 3d polylines
    By neil_morrish in forum AutoCAD General
    Last Post: 2004-07-22, 10:40 AM
