Thread: Project north vs True north - Project Basepoint and Survey Point Y-Axis's points to?
    2016-02
    35
    Default Project north vs True north - Project Basepoint and Survey Point Y-Axis's points to?
    I was wondering if I'm correct in stating that the project basepoint Y-axis ALWAYS points to project north, and the Survey Point Y-axis ALWAYS points to true north?
    2001-12
    Irvine, CA
    7,567
    Default Re: Project north vs True north - Project Basepoint and Survey Point Y-Axis's points to?
    The icons for each coordinate system are always oriented with their own systems, which may or may not be oriented correctly with your project or its site.
    2016-02
    35
    Thanks for the reply Steve. However whether or not they're correctly rotated and oriented in the project yet, I believe the the Y-axis for both the Project Basepoint and Survey Point, will ALWAYS point to their Project North and True North directions respectively. Obviously when you start a project, they both point up in the same direction, but I wanted to make sure for the sake of opening future projects and being able to quickly see where PN and TN are just by looking at the Y-axis of both the PBP and SP.
    100 Club a_meteni's Avatar
    2002-12
    Cairo
    174
    When you start a project, the property map will include the True North (normally aligned with Y-axis direction). The property major axis will never be 100% aligned with True North and It is very difficult to do any kind of design if everything is at an odd angle! So we align the project north with the Y-axis to simplify the design process.
    It is normal to include the project North and the True North on the project Plot Plan along with the angle of declination.
  1. Replies: 0
    Last Post: 2011-12-03, 09:13 AM
  2. True North/Project North and Shared Coordinates
    By tsong in forum Revit Architecture - General
    Last Post: 2008-04-03, 03:16 PM
  3. True North Rotate and Project North Alignment
    By Firmso in forum Revit Architecture - General
    Last Post: 2007-06-13, 05:11 AM
  4. Need to show true North on DWGs, where is true North?
    By jlizann in forum AutoCAD General
    Last Post: 2006-11-17, 02:36 PM
  5. project north and true north arrow symbol
    By Justin Marchiel in forum Revit Architecture - Families
    Last Post: 2006-03-21, 07:49 PM
