Thread: Can't get rid of red dashed outline around an "idw" drawing view.
    2009-03
    13
    Default Can't get rid of red dashed outline around an "idw" drawing view.
    Hello All -
    I'm using Inventor Professional 2020, Build 239, Release 2020.1.1 - Date: Mon 09/02/2019.
    See attached pdf file. I realize a view of a drawing has a red dashed outline when I move the cursor arrow over it. What I would call the "main" view of the "idw" drawing I'm working on has a red dashed outline around it that won't go away, even I'm working on a different view or when I exit the drawing and come back to it. The red dashed outline also shows up when I print the drawing. Any ideas on how to get rid of the red dashed outline?
    Thanks for your time and help.
    2009-03
    13
    Default Re: Can't get rid of red dashed outline around an "idw" drawing view.
    I just figured out the answer to my own question. All I had to do was suppress the view, then unsuppress it.
  1. Replies: 1
    Last Post: 2015-11-10, 03:45 PM
  2. Replies: 5
    Last Post: 2011-11-11, 11:53 AM
  3. Replies: 12
    Last Post: 2009-02-23, 03:38 PM
  4. Get rid of "Line Styles"...
    By iru69 in forum Revit Architecture - Wish List
    Last Post: 2006-02-02, 11:34 PM
  5. Dashed lines not dashed in Layout view
    By pford in forum AutoCAD General
    Last Post: 2004-06-15, 07:54 AM
