Thread: 3d surfaces
    2014-07
    31
    Default 3d surfaces
    I would like to create the nose of this train in 3d but need to know if Autocad or revit would be better. Would be using some sort of surfacing that could connect two profiles or more.
    Turlock, CA
    6,421
    Default Re: 3d surfaces
    I would use Inventor, but the next choice would be AutoCAD. You might start with Recap and then import into AutoCAD.
    C:> ED WORKING....
    LinkedIn
    2014-07
    31
    Is there a feature in autocad to connect two profiles with a surface. I know there is in Revit.
    Turlock, CA
    6,421
    AutoCAD doesn't have much support for surfaces, mostly solids.
    C:> ED WORKING....
    LinkedIn
  1. Swap surfaces in volume surfaces
    Last Post: 2018-10-17, 10:09 PM
  2. 2014: Compare Surfaces/Report Surfaces Through XREFFED Models
    By Jeff@BOC in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2014-04-24, 12:39 PM
  3. Creating Topo Surfaces Using 2-D topos
    By aggockel50321 in forum Revit Architecture - Tips & Tricks
    Last Post: 2007-06-04, 12:44 PM
  4. Topo surfaces: seeing new grading that's lower than existing
    By Wes Macaulay in forum Revit Architecture - General
    Last Post: 2004-03-09, 08:15 PM
  5. Dimensions of Topo Surfaces
    By gregcashen in forum Revit Architecture - Wish List
    Last Post: 2003-07-14, 04:43 PM
