Thread: Help fix a routine - Error: too few arguments
    2020-04
    Default Help fix a routine - Error: too few arguments
    Private Sub ToggleWireNum()
    Dim pi As Double: pi = 4 * Atn(1)
    Dim x As AcadEntity
    Dim lin As AcadLine
    Call WDForceStart
    On Error Resume Next
    For Each x In ThisDrawing.ModelSpace
        If TypeName(x) = "IAcadLine" Then
            Set lin = x
              If lin.Angle = pi Then
                ThisDrawing.SetVariable "USERS1", x.Handle
                WDCommand ("(setq return (c:ace_get_wnum (handent (getvar ""USERS1""))))" & vbCr)
                WDCommand ("(setvar ""USERS2"" (car return))" & vbCr)
                    If Len(ThisDrawing.GetVariable("USERS2")) > 0 Then
                        WDCommand ("(c:ace_toggle_inline (cadr return))" & vbCr)
                    End If
            End If
        End If
    Next x
    End Sub
    Public Sub WDCommand(Command As String)
    ' MsgBox ("WDCommand subroutine called.")
    ThisDrawing.SendCommand (Command)
    End Sub
    Public Sub WDForceStart()
    Call WDCommand("(if(not wd_load)(if(setq x(findfile ""wd_load.lsp""))(load x)))(wd_load)" & vbCr)
    End Sub
    2015-12
    51
    Default Re: Help fix a routine - Error: too few arguments
    Hi, Welcome to the AUGI Forums. Unfortunately you've posted this in the Autolisp Forum and it really should be in the VBA/COM Interop Forum. Perhaps a MOD can move it.
    Turlock, CA
    5,744
    Hi. I see this is your first post. Welcome to AUGI.
    You shouldn't try to mix lisp and VBA like this. The SendCommand method does not work like the (command) function. It is asynchronous. It runs after the vba method is finished. Therefore you are relying on variable that are not set until after the vba is finished. Convert the lisp to vba and it should work.
    Also, if you want help, it would be helpful if you provided as much information as possible, such as which line is giving the error. To add <CODE> tags to your post, click on Go Advanced at the bottom of the reply window, then select the <#> button.
    C:> ED WORKING....
    2008-02
    48
    Hi andy_skur
    Please let us know where system hangs,
    I suggest only to substitute
    with
    If TypeOf X is IAcadLine then
    concerning the section related to sendcommand I don't understand which is the functionality requested by sendcommand, in any case this part could be substitute with VBA code appropriate.
  1. Error: too few arguments in a function
    By twitchyChuck in forum AutoLISP
    Last Post: 2013-06-07, 09:24 PM
  2. Replies: 7
    Last Post: 2012-12-11, 01:41 PM
  3. Too few arguments, can someone check please?
    By mrsusan in forum AutoLISP
    Last Post: 2011-10-21, 12:00 PM
  4. Help fix a routine - Error: too few arguments
    By cadd4la in forum AutoLISP
    Last Post: 2006-01-10, 06:06 PM
  5. too few arguments on compile
    By voigtmark in forum AutoLISP
    Last Post: 2005-10-28, 06:54 PM
Tags for this Thread
