Thread: Sliding Window not uses actual Sections
    2005-09
    VARANASI in India
    338
    Default Sliding Window not uses actual Sections
    Is there family size reason as not to extrude metal sections in sliding window families ?
    Lallan Ji
    2015-08
    199
    Default Re: Sliding Window not uses actual Sections
    Yes families that have a lot of edges and faces can quickly up your file size if you have a lot of them (projects can easily have hundreds of windows). Most often just squared or somewhat boxed out shapes for the window frames/mullions is good enough for elevations and building sections. Then once down to detailing level you can add a detail item for the frame or have the detail item nested in the family and then only become visible at large scales and when cut.
  1. 2015: Revit Sliding Window Family
    By darkarch in forum Revit Architecture - Families
    Last Post: 2015-10-05, 04:05 PM
  2. 2015: Sliding window panels aren't showing
    By vanderloo5 in forum Revit Architecture - General
    Last Post: 2015-02-20, 05:29 PM
  3. 2013: Glider window with two sliding panels
    By johnholdingjr in forum ACA General
    Last Post: 2012-08-28, 11:52 PM
  4. Actual Content - Not good enough
    By darin.marsden in forum AMEP Wish List
    Last Post: 2010-02-09, 06:54 PM
  5. My office uses ACAD I use ADT
    By ksherrill in forum ACA General
    Last Post: 2004-12-20, 04:40 PM
