Thread: Revit print to pdf automation - unfortunately async
    All AUGI, all the time clog boy's Avatar
    2006-12
    Probably near a PC.
    843
    Default Revit print to pdf automation - unfortunately async
    So I'm trying to automate PDF printing to different sizes in Revit, and to do that I loop through a dictionary of sheet names and page properties (custom object).
    The problem is that in order to bypass the interface of the PDF printer (pdfforge PDFCreator), I need to address the queue and give each job a different output filename. I think I'm using the right code to do this, but by the time I'm looping through the queue it isn't fully populated yet. So I believe that the actual spooling works in a separate process, on a parallel thread. The same goes for the printer queue ofcourse.
    Fortunately, the queue outputs a bool when all jobs are received (have to set a number of jobs to await).
    Is there a way to halt code execution until that bool is set to True?
    EDIT found a solution... Feel free to delete this topic.
    2005-06
    in the upper right corner
    3,508
    Default Re: Revit print to pdf automation - unfortunately async
    Quote Originally Posted by clog boy View Post
    Please share your solution, so others looking for this topic or have a similar problem can find it.
    Thanks
  1. View / Sheet automation of a scheduled panel in Revit...
    By kjolly.248684 in forum Revit - API
    Last Post: 2011-01-31, 09:54 PM
  2. Revit Automation
    By ckeelor in forum Revit - API
    Last Post: 2009-12-19, 02:56 AM
  3. AutoCAD 2007 - DWG to PDF, Mac user unable to Open/Print PDF's
    By john.113502 in forum AutoCAD Plotting
    Last Post: 2006-06-06, 01:11 AM
  4. Revit Automation with VBA
    By kon.95959 in forum VBA/COM Interop
    Last Post: 2005-09-30, 03:56 PM
