Thread: pull out Label value (without exploding)
    2016-11
    Default pull out Label value (without exploding)
    Hi, How can i pull out Label value (without exploding) in C#?
    For example i need to pull out "L2958" in attached image by clicking on its label (without exploding).
    How can i do that by C#?
    5,806
    Default Re: pull out Label value (without exploding)
    You can explode to memory - that is, explode the Label within your Transaction, sorting the resultant components for the Type & extract the text contents you're after, and simply do NOT Commit().
    Cheers
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
  1. Replies: 0
    Last Post: 2013-07-26, 11:11 AM
  2. Pull Down menu dropping custom Pull downs one by one
    By lessZmore in forum AutoCAD CUI Menus
    Last Post: 2010-09-28, 10:34 PM
  3. Explode elevations without exploding hatches?
    By ynotbob2008 in forum ACA General
    Last Post: 2009-01-20, 03:08 PM
  4. 3D Slice how make one side 2" larger without exploding
    By sherflor in forum AutoCAD 3D (2006 or below)
    Last Post: 2006-03-02, 12:49 AM
  5. Get composition of a object block without exploding it
    By d.cakmur in forum VBA/COM Interop
    Last Post: 2005-04-04, 05:01 PM
