Results 1 to 8 of 8
Thread: civil 3d-plot labels
    2020-05
    4
    Default civil 3d-plot labels
    Hello!
    I have in my dwg a xref with caontours and their labels(contour single). In layout the labels are too big and cant see the rest of design. What is wrong?
    2014-08
    448
    Default Re: civil 3d-plot labels
    HI
    first check your contour interval and are labeling major and minor because you have multiple labels here
    2020-05
    4
    Quote Originally Posted by remi678731 View Post
    HI
    The problem still exists
    Cairo - no, not Illinois
    5,069
    generally speaking, I find it works better if I do my C3D labeling in the sheet file, rather than in a file I will be xreffing in. Also, specifically for topo, I do not display contours via an xref, instead DREF them into the model space of the sheet. That avoids a lot of problems with text conflicts and location.
    2020-05
    4
    The labeling was in a sheet file which was then uploaded to the file I will print.
    U meen its better the contours and their ladeling to copy paste to the flile when printing?
    5,069
    um no.... What happens when you plot to PDF from the sheet file? May way to upload a copy of your sheet file w/ xrefs so we can actually see what's there
    2020-05
    4
    This is....wanna plot it to 1:200
    5,069
    at 1mm=200m, you are zoomed so far out that the 3mm high labels are covering everything in the 36m wide area of topo
  1. Syntax examples of placing Civil 3D General Notes Labels in VBA
    By Capt. Computer Crasher in forum VBA/COM Interop
    Last Post: 2007-06-12, 09:16 PM
  2. Parcel labels won't plot
    By gadjet in forum AutoCAD Civil 3D - Parcels
    Last Post: 2007-01-18, 10:20 PM
  3. Plot 2 No Copies. 1st Plot is ok! 2nd Plot moves on the paper.
    By gianluca.giusti in forum AutoCAD Plotting
    Last Post: 2006-05-18, 11:02 AM
  4. Civil 3D: Moving Pipe Labels
    By dorseydesignservices in forum AutoCAD Civil 3D - Pipes
    Last Post: 2006-05-09, 05:57 AM
  5. Civil 3D 2006 Profile Structure Labels
    By dlash in forum AutoCAD Civil 3D - Pipes
    Last Post: 2006-04-27, 08:55 PM
