Results 1 to 8 of 8
Thread: Surface Slope Expression
    2009-11
    Raleigh, NC
    944
    Default Surface Slope Expression
    Can I write an expression to round up or down from .5 to whole #?
    2015-10
    Central New Jersey
    439
    Default Re: Surface Slope Expression
    How would this differ from setting the precision to 0 with normal rounding in the label style?
    2009-11
    Raleigh, NC
    944
    I cant get the .0% on the current label for a whole number
    2014-08
    448
    HI
    OK here we go if you want all the % at the whole number and yet read .0% (although I'm not sure why you would want that) in the dialog select the whole number precision then type in (.0%)
    Cairo - no, not Illinois
    5,069
    So, this is confusing. If I understand you, you want a slope of 2.500 to display as 3.0%? By showing significant figures to one decimal point, that would mean that the slope is between 3.05 and 2.95 -- that's a long way from 2.500, and potentially opening you up to ADA issues when display something that's not correct.
    2009-11
    Raleigh, NC
    944
    Its at shoulders of a gravel parking lot with GIS for existing topo. in order to keep grading object to a minimum the Shoulder edge feature line is a stepped offset. See the -4% shoulder labels. not a crtitical area so I want another label style supported by an expression that rounds from .5
    2014-08
    448
    HI
    so you said it make a copy of the style you want with the new parameters. Or what would do as I understand it especially for a steeped offset is make a typical cross section with various parameters
    2020-05
    2
    hola saludos a todos, estoy muy interesado en aprender la programación en excel con visual basic para autocad
    encontre este video en la red y quisiera saber si me podrian compartir información acerca del tema
    Attachment 108205Attachment 108206Attachment 108207
  1. 2012: Fill & Cut slope dont match assembly slope
    By chiju20 in forum AutoCAD Civil 3D - Corridors
    Last Post: 2014-11-14, 04:51 PM
  2. The tails of slope arrows must not lie in interior of slope defining lines.
    By Matt Mercer in forum Revit Architecture - General
    Last Post: 2010-10-07, 03:54 PM
  3. Define slope/grade by selecting on screen when placing points by slope/grade
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2009-04-24, 06:50 PM
  4. Railing Display on Straight Slope v. Curved Slope
    By pwilson.112560 in forum Revit Architecture - General
    Last Post: 2009-01-22, 05:50 PM
  5. Apply a slope to an area in a topo surface (Incliner une zone dans une surface topo)
    By gravelin in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-03-25, 01:23 PM
