Thread: Add text to structure tables
    Cairo - no, not Illinois
    5,069
    Default Add text to structure tables
    I'm doing work on military bases, a lot of renovation and adding new facilities/buildings into built up areas, which means connecting to existing utilities.
    In particular for sanitary and storm drain systems. The current crop of reviewers are requiring that the structure labels and tables explicitly label new incoming pipes as NEW, and the others as ABANDON, FILL, etc. Other than manually adding text on top of the dynamic pipe & structure tables, does anyone have a method that can help automate that? and minimize the probability of error creeping in?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Default Re: Add text to structure tables
    Are you currently using the Description property of the pipes in your labeling? Other than that, I cannot see a property that would be usable within the label or table styles to accomplish this.
    The Description property for structures and pipes is modifiable with AutoLISP.
    2021-05
    4
    I want to ask, how to add box in civil3d in the right station? Thank you.
  1. 2019: export pipe and structure tables
    By cadtag in forum AutoCAD Civil 3D - Pipes
    Last Post: 2019-10-21, 01:54 PM
  2. 2013: Alignment Segment Tables and Labels for Stake-Out Tables (Text Formatting?)
    By Patrick G in forum AutoCAD Civil 3D - Alignments
    Last Post: 2013-04-18, 07:09 PM
  3. Tables, Tables...........
    By TEAMSTAC in forum VBA/COM Interop
    Last Post: 2007-10-02, 05:01 PM
  4. Structure Data Tables
    By tpadgett in forum AutoCAD Civil 3D - General
    Last Post: 2007-08-09, 09:30 PM
  5. Microstation plot tables to AutoCAD plot tables
    By khager.72055 in forum AutoCAD Plotting
    Last Post: 2006-06-21, 12:34 PM
