Hi
Something a recent problem I had has hi-lited to me, which I'm sure all you techies out there already know, is the two 'Select Object' actions, one for the 'Polar' part of the action and the other for the 'Stretch' part of the action.
The only prompt is the two 'Select Objects' with no reference to the part of the action they are related to, so if only the 'Polar' or only the 'Stretch' action is required it's all about trial and error.
The action is called 'Polar Stretch' so it took a while to realise that Autcad in it's wisdom has made the first 'Select Objects' action the 'Stretch' part and the second 'Select Objects' action the 'Polar' part.!!!!!
It's probably mentioned somewhere in some piece of documentation but I haven't come across it!
Hope this helps someone struggling with this problem.
Geoff
