Results 1 to 8 of 8
Thread: Dimension standard changes on drawing close
    2020-05
    7
    Default Dimension standard changes on drawing close
    I have a VBA routine that that opens a template drawing and modifies and saves the drawing. The template Dimension Standard is "ANSI". After the drawing has been modified and saved the Dimension Standard is still "ANSI". However, after the drawing is closed and then reopened I get a dialog box that the drawing has one or more errors do I want to recover? If I say No then the drawing opens normally but the Dimension Standard is now "ISO" and I have no associated dimstyles. Changing the Dimension Standard to "ANSI" and saving eliminates the error. I'm at a loos to know what is causing this, It only happens with drawings that have been generated with the VBA routine.
    6,416
    Default Re: Dimension standard changes on drawing close
    Welcome to AUGI. Post your code so we can help you. In the reply window, click on Go Advanced and use the code tags button to wrap your code.
    LinkedIn
    2020-05
    7
    'Load template drawing if required
       If TempDwg <> "" Then
            Set objDoc = Application.Documents.Open(drive & TmplDwgPath & TempDwg, True)
       End If
    If Save = True Then
        DlFilename = drive & Path1 & Folder & DwgPath & SaveAsDwg.Dwg_Name.Text
        NewDwgExst = DlFilename & ".dwg"
        If Dir(NewDwgExst) <> "" Then
            SaveExst = MsgBox("Drawing Already Exists.  Overwrite?", vbYesNo)
            If SaveExst = vbNo Then
                GoTo saveDwg:
            End If
        End If
        ThisDrawing.SaveAs (DlFilename)
        Unload SaveAsDwg
    Else
        Unload SaveAsDwg
    End If
    What I have found is the problem only occurs with drawings that have been created with the VBA routine and are being saved as an earlier version of AutoCad. Until the drawing is closed the "AM Options\dimension standard" remains as "ANSI" even if it is saved again. Only when the drawing is closed and reopened does the "AM Options\Dimension Standard" change to "ISO". This does not seem to change if the drawing is saved as the same version of AutoCad that it was created in.
    6,416
    There's not very much here to go on.
    What does your Unload function do?
    There's nothing that saves as a previous version.
    Where is the option being changed?
    What are the errors being reported?
    LinkedIn
    2020-05
    7
    The unload function unloads a form/menu that allows the user to enter a drawing name.
    Our AutoCad is setup under "Options/Open and Save" to save as AutoCad mechanical 2013 Drawing (*dwg)
    The option being changed is "Options/AM Standards". The "Standard" is being changed from "ANSI" to "ISO".
    The error that I receive is: "One error was found in the drawing file during open. Would you like to cancel this open? It is recommended you cancel the open and then run the RECOVER command on the drawing file"
    Recover does nothing and the error remains until the "ISO" is changed to "ANSI"
    6,416
    I assume AM stands for AutoCAD Mechanical? I don't have that, but I am familiar with setting options. Can you show your code?
    I'm not sure that the Save method respects your choice in options to save to earlier version. I think you need to use the FileType option of the SaveAs method to specify what version to save to.
    LinkedIn
    2020-05
    7
    I have no code for setting options, all of the options are set when AutoCAD opens and I am not changing any of these.
    6,416
    I still don't see anything in the code you posted that modifies the dwg. Saving wouldn't do it. Can you post a dvb and sample dwg that I can test? Perhaps there is something wrong with the template.
    LinkedIn
  1. Replies: 7
    Last Post: 2018-04-13, 03:57 AM
  2. Close Revit without saving changes?
    By scowsert in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2007-06-22, 05:08 PM
  3. Close Revit without saving changes?
    By scowsert in forum Revit Architecture - General
  4. Close a file and don't save changes
    By jgardner.79905 in forum AutoLISP
    Last Post: 2006-08-21, 05:31 PM
  5. How do I close the file *without* saving changes?
    By iru69 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2005-06-23, 03:40 AM
