Thread: error message
    2004-06
    Slidell, Louisiana
    828
    Default error message
    where do I have to go to clear this up?
    Robert
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    Default Re: error message
    I'm pretty sure the "Add-A-Plotter Style Table Wizard.lnk" is from an older version or corrupt. Try copying the file from your most recent installation to the folder on your D:\ drive. Mine is located here "C:\Users\paulsenj\AppData\Roaming\Autodesk\C3D 2020\enu\Plotters\Add-A-Plotter Wizard.lnk". You may want to make a copy of the current file on the D:\ drive just in case.
    Jeff Paulsen
    Earth
    9,788
    Just go to the folder mentioned and delete that file. That's all there is.
    R.K. McSwain | CAD Panacea |
    2004-06
    Slidell, Louisiana
    828
    thanks, that did the trick
    Robert
  1. Replies: 12
    Last Post: 2006-12-07, 03:22 PM
  2. Error Message: Display Error
    By mccurdyks in forum Revit - Hardware & Operating Systems
    Last Post: 2006-07-19, 07:21 PM
  3. Replies: 2
    Last Post: 2005-12-06, 06:17 PM
  4. Error message - Fatal Error 3300ED19H
    By flipup73 in forum AutoCAD General
    Last Post: 2005-10-28, 04:30 PM
  5. Fatal Error: Unhandled Exception" Error Message
    By jkrulicki in forum MDT - General
    Last Post: 2004-07-28, 03:56 PM
