Thread: Convertpstyle
    2009-11
    Raleigh, NC
    707
    Default Convertpstyle
    The last project I convrted acad.ctb to .stb. My plot styles are on my C: drive.
    Why do I have to convert the acad.ctb again instead of just convertpstyle command only now?
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,366
    Default Re: Convertpstyle
    You started with the wrong ctb file. AutoCAD comes with both acad.ctb and acad.stb and you shouldn't modify any of the installed ones.
    When stb's were introduced years ago I saved acad.ctb as acad - Convert.ctb and created acad - Convert.stb using convertctb. I've used them ever since and the names make it clear what they're for.
    Tom Beauford P.S.M. - Civil 2020 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    2009-11
    Raleigh, NC
    707
    I am reading what seems to be a conflicting statement telling me not to convert the standard autocad pen tables but it seems that you are saying you did that years ago too? ???
    I understand what the named commands are.
    So if my company is using acad.ctb the how do I make autocad read acad.stb? the convertpstyles dictates I convert the ctb file.
    2001-03
    Tallahassee, FL
    3,366
    Quote Originally Posted by tim_newsome View Post
    I've never actually changed or even used acad.ctb I opened acad.ctb and saved the file as as acad - Convert.ctb.
    We use the Florida Dept of Transportation stb file and I have a macro to set FDOT.stb
    ^C^C^P(or C:FDOT255(load "FDOT255.lsp"));FDOT255
    using this lisp:
    ; Set drawing settings to FDOT.stb
    ; (load "FDOT255.lsp") FDOT255
    ; ^P(or C:FDOT255(load "FDOT255.lsp"));FDOT255
    (defun c:FDOT255 ()
     (if(=(getvar "PStyleMode") 1)(command "_convertpstyles" "acad - Convert.stb"))
    ; (cond(=(getvar "DwgTitled")0)(alert "Drawing must be saved first!")(exit))
     (vla-put-StyleSheet
        (vla-get-ActiveLayout (vla-get-ActiveDocument (vlax-get-acad-object)))
        "FDOT.stb"
      (setq layers (vla-get-layers(vla-get-ActiveDocument (vlax-get-acad-object))))
      (vlax-for l layers
        (progn
     	(cond
       	  ((equal (vla-get-color l) 8)(setvar "CPLOTSTYLE" "125")(vla-put-plotstylename l "125"))
       	  ((equal (vla-get-color l) 9)(setvar "CPLOTSTYLE" "125")(vla-put-plotstylename l "125"))
       	  ((equal (vla-get-color l) 250)(setvar "CPLOTSTYLE" "125")(vla-put-plotstylename l "125"))
       	  ((equal (vla-get-color l) 251)(setvar "CPLOTSTYLE" "125")(vla-put-plotstylename l "125"))
       	  ((equal (vla-get-color l) 252)(setvar "CPLOTSTYLE" "125")(vla-put-plotstylename l "125"))
       	  ((equal (vla-get-color l) 253)(setvar "CPLOTSTYLE" "125")(vla-put-plotstylename l "125"))
       	  ((equal (vla-get-color l) 254)(setvar "CPLOTSTYLE" "125")(vla-put-plotstylename l "125"))
       	  ((equal (vla-get-color l) 255)(setvar "CPLOTSTYLE" "Normal")(vla-put-plotstylename l "Normal"))
       	  (T(setvar "CPLOTSTYLE" "255")(vla-put-plotstylename l "255"))
      (setvar "CPLOTSTYLE" "ByLayer")
      (princ)
    We get a lot of drawings from outside and as long as they're using Civil 3D standard template colors the drawings plot as expected after conversion.
    HTH
  1. 2020: Convertpstyle
    By tim_newsome in forum AutoCAD General
    Last Post: 2020-03-31, 07:10 PM
