Results 1 to 1 of 1
Thread: Multiple Visibility Parameter Lisp
    2011-10
    Norfolk England
    57
    Default Multiple Visibility Parameter Lisp
    Hi Me Again
    Not sure if it's here or Programming Forum to post this!!!
    I am trying to use the visibility add lisp routine, I aquired from the web, to add more than one Visibility Parameter but am getting an error after loading the first one .....
    Command: VISIBILITY_ADD
    Select point for placing Visibility Set: _.point
    Current point modes: PDMODE=3 PDSIZE=0.37500000
    Specify a point: 0,0,0
    Command: ; error: bad DXF group: (360)
    Have attached the lisp routine perhaps somebody more clued up than me with lisp routines can have a look!
    Thx
    Geoff
  1. 2018: link Visibility, Linear Parameter, or Point Parameter to CTAB value
    By dgregory85 in forum Dynamic Blocks - Technical
    Last Post: 2018-09-20, 03:58 PM
  2. 2015: Yes/No parameter controlled by multiple other visibility Yes/No parameter in one family.
    By gross695874 in forum Revit Architecture - General
    Last Post: 2015-10-05, 03:05 PM
  3. LISP to Change Visibility Parameter
    By kwest in forum AutoLISP
    Last Post: 2014-08-07, 06:37 PM
  4. Yes/No Visibility Parameter with Secondary Parameter Help
    By bpayne in forum Revit Architecture - General
    Last Post: 2011-06-15, 05:52 PM
  5. All lisp in one or multiple lisp ???
    By Dubweisertm in forum AutoLISP
    Last Post: 2010-08-19, 04:21 PM
