When I receive models from consultants I run dynamo to put certain items on shared levels and grids so I can turn them off easily in my model.
Some models I receive are not set up to be a central model, so I do so, so I can dynamo to clean things up.
The problem is the ID is different every time I do this on the same model when I get an update.
So when I reload the model the workers that were turned off get reset.
Does anyone know how I can change the ID of a workset so I can keep it consistent when repeatedly create a workshare model each time i get an update?
Or is there another way to take of this problem?
Also I'm assuming this is my problem of why when loading anew model the worksets that are turned off get reset, this doesn't happen with other models that already have worksets.
