What is the Command to type "Import Text". Is there a way to call up "Import Text" at the command line?
Or automated way to call up the command (ie: Lisp program - to located .rtf files to import) besides using the MTEXT- import text function for each file?
METHOD: The only way I have find to insert a txt.rft file is; while in MTEXT - Text Editor>> Right Click>> select "Import Text".
Separate file window ups up to navigate to folder and you can locate the folder where the file resides.
Office uses ACAD LT 2020 & ACAD 18 Full version.
