Results 1 to 7 of 7
Thread: disappearing text in paper space
    2004-06
    Slidell, Louisiana
    816
    Default disappearing text in paper space
    I have several layouts in my drawing (6). in one particular layout when i try to create mtext or dtext in paper space (not annotative), as soon as I click to accept it, it disappears.
    I can create it in model space no problem. i have recovered, run audit, closed and reopened both the dwg and the software, rebooted the machine, nothing has solved the problem.
    it's just that one layout that this happens in. i've wblocked, copied and pasted, used design center, still no. luck.
    i keep getting a warning: an error occurred during save. we recommend that you run RECOVER on the drawing.
    which I've done numerous times.
    Help.....
    Robert
    Civil Engineering Moderator MHultgren's Avatar
    Central Iowa
    1,431
    Default Re: disappearing text in paper space
    What happens when you create it in modelspace and then use changespace to bring it into Paperspace? And the layer you are using isn't frozen or turned off in Layouts?
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
    2004-06
    Slidell, Louisiana
    816
    Quote Originally Posted by MHultgren View Post
    Same thing, it disappears once it's in paper space.
    and all layers are on and thawed.
    Robert
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,365
    Sounds like the layer isn't Frozen but is "Frozen in the current viewport". The Paper Space of a layout can also be "Frozen in the current viewport" allowing you to create the text or draw lines or other objects but you will not see them until you "Thaw in the current viewport".
    Have you tried drawing lines on that same layer in that layout?
    Have you tried using a different layer?
    Layouts can be corrupted, it's happened to me but I've only seen it cause issues inside viewports. I've had to reconstruct them before.
    Tom Beauford P.S.M. - Civil 2020 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    2004-06
    Slidell, Louisiana
    816
    I didn't think of that one. thanks for the idea. I'm working from home today, but i will certainly try that when i get back to the office.
    no, nothing other than text.
    Robert
    2004-06
    Slidell, Louisiana
    816
    Well it turns out it wasn't any of those things. It was text style. don't know why, but once I changed the text style to something else, everything worked fine.
    anybody know why a text style would cease to work in paper space? same style works fine in model space.
    what's crazy is that same text style works fine in all the layouts and paper space, just not that one layout.
    Robert
    2005-06
    in the upper right corner
    3,269
    Quote Originally Posted by rmk View Post
    I have no idea but is there something different about the text style (font) like a TTF vs. an SHX?
    And maybe that particular layout has a different "visual style" that doesnt match the others? 2D wireframe etc.
    Ted
    ____________________________________________________________________ ________________
    Windows 10
    AutoCAD 2018 - REVIT 2019 - Inventor Professional 2017 (when I can)
  1. 2004: Paper space text behind model space solid hatch while viewing
    By david1030 in forum AutoCAD General
    Last Post: 2017-06-05, 09:12 PM
  2. 2011: Text shows up in Model Space but not Paper Space
    By rbelling974531 in forum AutoCAD General
    Last Post: 2015-12-03, 12:22 PM
  3. Replies: 2
    Last Post: 2010-03-23, 07:22 PM
