Thread: Section / Elevation - Bathroom partition overlapping toilete
    2019-03
    2
    Post Section / Elevation - Bathroom partition overlapping toilete
    I am attempting to make an interior elevation of an ADA bathroom stall. (I have tried both a section and an elevation). For whatever reason the partition is showing up in the foreground above the toilet, even though in plan it is obviously behind the toilet. The partition is Bradley, and the Fixture is toto. Any ideas?
    - - - Updated - - -
    (I attached the screenshot of the section in the NON-ada stall--for you nit-pickers out there)
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    442
    Default Re: Section / Elevation - Bathroom partition overlapping toilete
    Is the partition set one object? And is its category "Specialty Equipment"? Specialty equipment does not "cut", so it always shows in elevation if a cut line crosses it. It's easy enough to change the family category to "Generic Model" to get the results you want.
    While I played around with the Bradley partition family a bit, I finally settled on my own partition pieces that are not one massive family, but more a kit of parts for flexibility. This also allows the partitions to stay in the Specialty Equipment category while still getting the desired results as the end/door panels are not the same model object as the side panels.
    2019-03
    2
    I changed the category to "Generic Model" and it didn't work.. Yeah, I just like to use the manufacturers products whenever possible. And this is really annoying... I tried tgoing into the family and changing a few things around. But no luck... I'm surprised this isn't a more common problem...
    2010-10
    Chicago, IL
    376
    In addition to changing the category, you need to turn off the masking region and turn on partitions’ visibility in the elevation view. It should work as expected now. File attached here.
  1. 2018: Use Section View to Achieve Isometric Presentation with Overlapping Features
    By warwickpeter in forum Revit Architecture - General
    Last Post: 2018-05-23, 03:02 AM
  2. 2013: Elevation View Titles Overlapping
    By tcrawford1978 in forum Revit - Conceptual Design Tools
    Last Post: 2012-10-18, 03:44 PM
  3. bathroom equipment
    By mwittens83539 in forum Revit Architecture - Families
    Last Post: 2005-03-25, 04:11 PM
  4. Bathroom Light/Fan combo
    By J. Grouchy in forum Revit Architecture - Families
    Last Post: 2004-11-28, 10:25 PM
  5. typcial bathroom and kitchens ready
    By Wagurto in forum Revit Architecture - General
    Last Post: 2004-08-02, 02:32 PM
Tags for this Thread
