Autocad 2017 LT - when I try to draw an object, it is being squeezed into a single vertical line. I've lost ortho control.
I must have changed a setting somewhere, can someone help?
Did you rotate your viewcube?
Have you checked your UCS settings? Just to make sure you're placing objects in the correct work plane.
