Thread: BACK UP FILES
    2005-04
    Saintlouis Missouri
    529
    Default BACK UP FILES
    Well I really messed up yesterday. I ended up saving a file from 2019 to 2020 and I did not mean to do that. I am trying to find the back up files so I can get it back. Can anyone lead me in the right direction please?
    2002-09
    Madison, WI
    5,687
    Default Re: BACK UP FILES
    Well, you might be able to find an older version in your where you're local files were if it was a workshared modeled.
    If it's not workshared, you might be out of luck, unless you have a nightly backup.
    When you opened the model in 2020, you should have gotten that big warning dialog box that says something like "You're about to upgrade to a 2020 version"
    You can't really go back and I don't know that any of the back up files are going to be helpful.
    Might want to contact Autodesk Direct about that one. I was told a while ago that while Autodesk says you can't go backwards, apparently you can, it'll just cost you a small fortune.
    2020-07
    London
    11
    At revit everything is bad with backups. If it is a local file - look for files: .0001.rvt .0002.rvt, etc. (but it rarely helps )
    I can advise you for future plugin: https://apps.autodesk.com/ACD/en/Det...n64&appLang=en
  1. back to back functions
    By mbrandt5 in forum AutoLISP
    Last Post: 2015-05-21, 12:34 PM
  2. 2013: Back To Back Mullions on Storefront - how do i do it?
    By bwilliams133 in forum Revit Architecture - General
    Last Post: 2013-06-21, 06:43 PM
  3. back to back toilets
    By moliva in forum Revit MEP - General
    Last Post: 2009-11-25, 04:48 PM
  4. Back to Back WT
    By justin.biddle in forum Revit Architecture - Families
    Last Post: 2009-09-11, 04:12 PM
  5. Back-up copies of rvt files
    By Wagurto in forum Revit Architecture - General
    Last Post: 2004-08-20, 02:37 PM
