Thread: attribute (annotative) in block disappears when changing scale
    2011-07
    The Netherlands
    63
    Question attribute (annotative) in block disappears when changing scale
    Hi All!
    I have a block with an attribute (lock position and multiple lines: Yes) in it.
    The block is not annotative, but the attribute is. When changing the scale of the drawing, the attribute disappears!
    Very weird and I can't fix it. ATTSYNC works for this scale, but when changing the scale and use ATTSYNC, it shows up, but when going back to the other scale I lose the attribute again
    example of my workflow:
    - placing block in drawing scale 1:100 -> ATT shows up. fine
    - changing drawing scale to 1:50 -> ATT disappears. bad
    - using ATTSYNC -> ATT shows up. fine
    - changing drawing scale back to 1:100 -> ATT disappears. bad
    Does anyone have the same problem and know to handle this?
    I need it work at both scales, because I use this block in different sheets with different scales in one drawing.
    Thank you in advance!
    2005-06
    in the upper right corner
    3,507
    Default Re: attribute (annotative) in block disappears when changing scale
    Quote Originally Posted by peysey View Post
    Hi All!
    Do you have all the scales assigned to the attribute? you should have at least those two?
    It may be working when you do an attsync because you have it automatically adding annotative scales to objects you change your scale?
    Just a thought
    2015-05
    West Des Moines
    306
    Does Attsync bring it back when you go back to 1:100? Have you tried printing it before changing the scale to see if it does what you want?
    If so and when you change back to 1:100 and it disappears have you tried attsync again to correct it? Also have you just tried plotting it just to see what it does when it disappears? In my experience some of those more complicated blocks don't always update properly in CAD, but when printing they work. Going to guess in the case of Attsync issues that it won't, but something to try to cross it off the list.
    2001-10
    Defragging the internets.
    350
    If you set ANNOALLVISIBLE to 1 and toggle the scales, does it show up?
    2011-07
    The Netherlands
    63
    Guys,
    Thank you very much for your detailed help.
    I found out that if you select all objects in the block and turn ANNOTATIVE OFF for everything inside a block and deselect everyhing and than turn ANNOTATIVE ON for the block itself, it works better : )
    So the ATT doesn't have to be ANNOTATIVE. The BLOCK has to be.
    The reason I didn't use this metod was because I thought that linework was not scaling well (tried some time before). I tried again and I saw that you have to do REGENALL to fix the scaling of linetype... Really annoying, because you sometimes forget to regen..
    However, this works
    Thank you anyway!
  1. Annotative block moving when changing scale
    By Jonathan Pitt in forum AutoCAD LT - General
    Last Post: 2013-03-13, 10:40 PM
  2. 2011: annotative text and annotative block failure
    By kuruczregina in forum ACA General
    Last Post: 2012-03-25, 06:56 PM
  3. Replies: 0
    Last Post: 2011-11-17, 04:25 PM
  4. Annotative Attribute in Non-Annotative Block
    By c.mcmahon in forum AutoCAD Annotation
    Last Post: 2010-04-09, 08:23 PM
  5. Annotative attribute in non-annotative block
    By thegreyguy in forum AutoCAD Annotation
    Last Post: 2009-07-24, 03:58 PM
Tags for this Thread
