Thread: SSM placing view best practices
    Default SSM placing view best practices
    Hello!
    Just getting back into using SSM. Used it quite a bit years ago. One thing I don't believe I ever sorted out was a best practice on placing views.
    When you place a view, it seems to put the label block, and the viewport on the same layer. Obviously I want the viewport on the VPORT Layer so it doesn't print the outline of the viewport. The label block I want on another layer. Is there a way to make this happen automatically? It'd be one less thing I have to manually fix on every sheet.
    Thanks!!
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,084
    Default Re: SSM placing view best practices
    You want additional automation when it comes to SSM? Unfortunately, I don't see that happen. I don't think SSM has been modified since it was introduced.
    If you have full AutoCAD (and not LT), then you could get some automation added after the fact to move your viewports to the VPORT layer. You might search our AutoLISP programming forum to see if anything is already shared on here.
  1. Revit Best Practices (RBP) - View Naming
    By Kevin Janik in forum Revit - In Practice
    Last Post: 2015-06-01, 06:36 PM
  2. 2013: Best practices for tiny firm sharing Revit Central files - Best step past dropbox? VPN? Revit Server?
    By spletz240993 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2013-09-12, 10:49 PM
  3. Parent view - best practices
    By petervanko in forum Revit Architecture - General
    Last Post: 2007-06-13, 04:17 PM
  4. Relative X-Ref Paths when placing views via SSM
    By cblackford in forum AutoCAD Sheet Set Manager
    Last Post: 2007-04-23, 05:41 PM
  5. Placing label blocks after placing the view with SSM
    By bskripac in forum AutoCAD Wish List
    Last Post: 2005-01-27, 04:01 PM
