Thread: Twisted View Zoom Object or Extents
    Wish List Administration
    2011-08
    4,581
    Default Re: Twisted View Zoom Object or Extents
    Summary: Twisted View Zoom Object or Extents doesn't fit either to full screen
    Description: Twisted View Zoom Object centers but only fill extents when the objects are rotated to match DVIEW TWist angle.
    Zoom Extents is just as bad.
    Simple commands like this should work for Civil 3D users as well.
    Product and Feature: AutoCAD Civil 3D - Civil View
    Submitted By: Tom Beauford on 07/21/2020
    Tallahassee, FL USA
    3,658
    I found a solution to Zoom Object in a Twisted View at least by gile at The Swamp
    Zoom out to fit an object into screen: https://www.theswamp.org/index.php?t...0028#msg250028
    Placed the code for ZoomObject and the test/calling function: zo in one file and changed zo to zob since ZO is defined in c3d.mnl as Zoom Out.
    Enter zob at command line to Zoom to Objects in twisted views.
    As the TIN-Surface is usually the area I'm working in I added this code to the bottom of the same file for Zooming to Surface
    (defun c:zs (/ lastent ss)
      (or *acdoc*
          (setq *acdoc* (vla-get-ActiveDocument (vlax-get-acad-object)))
      (setq ;lastent (entlast)
            ss (ssget "X" '((0 . "AECC_TIN_SURFACE")))
      (if (>(sslength ss)0)
        (progn
           (vla-StartUndoMark *acdoc*)
           (command-s "LineworkShrinkwrap" ss "")
           (c:zob)
           (command-s "erase" "_previous" "")
           (vla-EndUndoMark *acdoc*)
    Then added this zet function below it to do the Zoom Extents in Twisted View to full screen.
    (defun c:zet (/ lastent ss)
      (or *acdoc*
            ss (ssget "X")
        (progn
           (c:zob)
    Last edited by Tom Beauford; 2020-07-22 at 04:23 AM. Reason: Added more code and information.
