Is it possible to create a dynamic block that will evenly distribute an object at a "No Greater Than Distance" and evenly place them between two fixed end objects such has a Handrail with brackets? If the two end brackets are closer than 48" it will not add a bracket. If they are farther apart than 48" it will add a bracket(s) between them evenly distributed. I have seen someone ask a similar question from 2017 about an angle iron with holes drilled in it. But they used over 20 stretch actions on a single Parameter. There has to be an easier way. Thank you in advance.
