Results 1 to 1 of 1
Thread: Exact same lineweight thickness setting in CAD/Revit....but Revit still prints thicker!
    2016-02
    35
    Default Exact same lineweight thickness setting in CAD/Revit....but Revit still prints thicker!
    So I have a lineweight specified at .0197" for both AutoCAD AND Revit, and at first Revit seemed to print thicker. I believe the issue was I was zoomed in more in Revit than I was in AutoCAD and I printed using the "Visible portion of current window". I plotted AutoCAD from a sheet. So because I zoomed into the view in Revit, the lineweights appeared thicker in Revit but in reality, they're still both .0197". Can anyone confirm that the further zoomed in you are in Revit, the lineweights will appear/print thicker regardless of the lineweight settings? CADvsRevit Detail.PNG
  1. CTB lineweight vs. Layer List lineweight
    By mcasella in forum AutoCAD General
    Last Post: 2007-11-08, 01:02 PM
  2. Can I make lines in block plot thicker?
    By jgratton in forum AutoCAD Plotting
    Last Post: 2006-11-30, 05:27 PM
  3. Thickness vs Foundation Thickness
    By eric.anastas in forum Revit Architecture - General
    Last Post: 2006-11-10, 08:12 PM
  4. Some MText characters look thicker than others
    By chrisr in forum AutoCAD General
    Last Post: 2006-09-13, 07:56 AM
