Thread: ACAD LT2021 Custom Hatch
    2005-01
    59
    Default ACAD LT2021 Custom Hatch
    We have several clients that share the same floor in our building. To define the areas, currently I do a poly line on the floor plan, close, then click on hatch, select a pattern then the poly line as the object. Rather than using one of the line patterns, I would like to have the name of the client shown as the pattern instead. I saw something about Superhatch command which doesn't seem to be an LT option. Any advice would be most appreciated.
    9,779
    Default Re: ACAD LT2021 Custom Hatch
    Correct, Superhatch is part of express tools, which do not operate in AutoCAD LT.
    You can go into your ACADLT.PAT file and rename an existing hatch pattern (see image), or create a new pattern and name it whatever you want.
    The default location for this file is %AppData%\Autodesk\AutoCAD LT 20xx\Rxx\enu\support
    2005-01
    59
    Sorry I wasn't clearer, I don't want to change the name of the file to the client but have the pattern appear with clients name. I suppose I could always just create a text and copy and paste as shown in the attached but was hoping to just have the one name and the pattern would generate within the given border.
    9,779
    Oh, that is do-able, you just need to create a hatch pattern that will look like your client's name.
    Start here: http://help.autodesk.com/view/ACDLT/...6-0CA817ADD77E
    2003-07
    418
    Making hatch patterns is a bit of an art there is make hatch pattern software out there such as hatchkit but again not in LT. This link may be helpful.https://www.cadtutor.net/forum/topic...comment-567281. If you have access to autocad hatchmaker.lsp may be useful also, trying to find the link at Cadtutor with some other hatch making software.
    You can explode text maybe LT so could make a block with nice internal shading and use array to multi copy.
    I could stop if I wanted to hugh.69031's Avatar
    2016-01
    Melbourne, Australia
    359
    ...but again not in LT.
    For the record, HatchKit creates and edits patterns ready for use within both AutoCAD LT and AutoCAD as the pattern definition files are identical.
    Until we provide text-based patterns directly from HatchKit a feasible workflow is:
    1. Set up text in AutoCAD or AutoCAD LT employing any suitable SHX font (simpler fonts result in lighter, less complex patterns).
    2. Explode the text.
    3. Export the text as DXF.
    4. Open DXF file in HatchKit, arrange the text as desired then save to .PAT file
    hth,
    Hugh Adamson
    www.hatchkit.com.au
  1. Get custom hatch patterns to show on Custom tab in Hatch dialog box
    By bberghahn in forum AutoCAD Customization
    Last Post: 2006-11-07, 08:17 AM
  2. Need to covert 1992 Acad dwgs to present 2004/5 Acad!
    By anapier in forum CAD Management - General
    Last Post: 2005-02-17, 05:51 AM
  3. What's the difference between Acad 2005 & Acad 2005 Mechanical!
    By Cosmic Traveller in forum AutoCAD Mechanical - General
    Last Post: 2004-07-02, 08:42 PM
  4. Can Acad 2005 run with Acad 2002 Together
    By Cosmic Traveller in forum AutoCAD General
    Last Post: 2004-07-01, 06:52 PM
  5. Revit does ACAD better than ACAD
    By mikesheehan in forum Revit Architecture - General
    Last Post: 2004-01-14, 01:47 PM
