Results 1 to 8 of 8
Thread: civil objects labels not scaling correctly
    2014-08
    448
    Default civil objects labels not scaling correctly
    Hi
    Got a new one here. It seems that cogo points and line labels are not adjusting the displayed text when the scale is changed in model space. This seems to an issue with windows ten. Has anybody else seen this or do they have a fix
    2015-05
    West Des Moines
    306
    Default Re: civil objects labels not scaling correctly
    I am on windows 10 pro, but I have never used 2019, jumped from 2018 to 2020 and have not seen this issue.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Are you referring to the scale of labels when viewed through a viewport contained in a layout? If so, those are based on the viewport scale regardless of the model space scale. If you are only referring to viewing those elements in the model layout tab, then try a regen after the scale change.
    2014-08
    448
    HI
    referring to modelspace and regen and regen all neither worked
    2015-10
    Central New Jersey
    439
    Are the 'points' being viewed real civil 3D points with labels or are they autocad points/blocks?
    2014-08
    448
    Hi
    They are real civil3d cogo points
    Earth
    9,805
    Quote Originally Posted by remi678731 View Post
    Hi
    Post the DWG file (or a stripped down version of it that still exhibits the problem)
    R.K. McSwain | CAD Panacea |
    2014-08
    448
    HI
    not my file I was just helping a friend. but it seems the issue resolved itself must have been a video card issue.
    I got an email from when he opened this morning everything seemed to be working. will have to see if it returns
  1. Annotative Dynamic Blocks not scaling correctly. Please help!
    By NickD22 in forum CAD Management - General
    Last Post: 2017-03-07, 01:06 PM
  2. OLE (eg Excel) Objects within drawing file not Plotting correctly
    By Mike.Perry in forum AutoCAD FAQ (Read only)
    Last Post: 2013-01-21, 02:27 PM
  3. x-refed profile labels are not oriented correctly
    By therealjd in forum AutoCAD Civil 3D - General
    Last Post: 2010-11-09, 03:56 PM
  4. Civil 3D Objects not displaying correctly in Civil 3D 2008
    By xstat21x in forum AutoCAD Civil 3D - General
    Last Post: 2007-05-10, 01:36 PM
  5. Replies: 17
    Last Post: 2007-03-28, 05:40 PM
