Thread: Get data from command line
    2020-07
    14
    Default Get data from command line
    Hello Everyone
    I want to get the texts that come after I activate the command "id". That says "Specify point: x=#### y=####"
    how do I do it?
    Here is the code.
    Public Sub tryer()
    ThisDrawing.SendCommand "id" & vbCr
    End Sub
    5,737
    Default Re: Get data from command line
    You can't because the SendCommand method is asynchronous. You need to define your own ID command, which is pretty simple. Use the GetPoint utility and examine the x and y values of the returned point. There is sample here.
  1. Replies: 4
    Last Post: 2014-01-01, 07:58 PM
  2. Replies: 0
    Last Post: 2009-04-15, 02:42 PM
  3. Replies: 5
    Last Post: 2006-11-09, 07:19 PM
  4. Command Line Or No Command Line?
    By H-Angus in forum ACA General
    Last Post: 2006-03-01, 12:18 PM
