Thread: AECC_CONTOUR
    Raleigh, NC
    944
    Default AECC_CONTOUR
    Best practice to create a surface from AECC_CONTOUR lines?
    2014-08
    448
    Default Re: AECC_CONTOUR
    Under surface definition the option to add data from objects there is a option for contour data, check the box to minimize flat areas. This is almost always the last resort for me to create surface, it is the least accurate method there is. Rarely do the new contours follow the old without a lot of manipulation.
  1. Aecc_contour
    By okonforti.91529 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2008-07-08, 06:54 PM
