Thread: Multiple text lookup in dynamic block
    2015-05
    West Des Moines
    306
    Default Multiple text lookup in dynamic block
    I know blocks only allow one visability state per block (which saddens me), but is there a good way to put in multiple ways to lookup different text-based information? We have separate dynamic license seal and office location blocks that aren't part of the actual titleblock and I was looking at trying to incorporate them into it since users are requesting a dynamic titleblock that they can scale based on page demand which is simple enough, but since these two chunks of information lay outside of the titleblock they won't move with it. I was thinking lookup tables would help with this, but it seems designed for parameters when I am just trying to find a way to display multiple forms of mtext-based information.
    Thanks for the help.
    2015-10
    Central New Jersey
    439
    Default Re: Multiple text lookup in dynamic block
    We use a Block Table in our dynamic title block for switching the signing professional's name and license numbers.
    You can link a Lookup to an Attribute to provide a selection of text values. Add a Lookup Set, add values in the far right column, set the default value of the attribute to be a field (blockplaceholder) and select the name of the Lookup. Insert a new block for testing.
    2015-05
    West Des Moines
    306
    Thanks for the tip MMccall, just started playing with it and this looks like a great solution for the office info portion in our case, maybe will be able to use it in other areas as well. My seal block is...sealy...because it accommodates for multiple states and personal desires so trying to get it setup for that seems more work than I want to put into that part.
    2015-10
    Central New Jersey
    439
    One other thing: Block tables and lookup values don't allow you to directly type in line shifts into their editors, however you can paste in values with line shifts and they'll work just fine with a multilined attribute.
    2015-05
    West Des Moines
    306
    I think I kept it pretty simple by creating a separate attribute for each line of the office info. If I had one complaint it's that I felt the need to create a fake attribute on the defpoints layer so that the list looked good when a user would select through them, but that's a small price to pay.
  1. Lookup Properties Visibility states settings in A Lookup Table
    Last Post: 2017-12-01, 05:53 PM
  2. 2016: Lookup based on a Lookup
    By dkennard in forum Dynamic Blocks - Technical
    Last Post: 2017-01-20, 12:59 AM
  3. Having trouble accessing the lookup values of a Dynamic Block
    By cadconcepts in forum Dynamic Blocks - Technical
    Last Post: 2006-07-19, 03:43 PM
  4. Can somebody supply me with an example of a dynamic block that uses lookup parameters
    By robert.1.hall72202 in forum Dynamic Blocks - Technical
    Last Post: 2005-12-08, 09:01 PM
  5. Dynamic Block lookup table
    By mvillamorel in forum Dynamic Blocks - Technical
    Last Post: 2005-07-14, 09:54 PM
