Thread: opening dwg with current Civ3D through windows instead of outdated version
    Raleigh, NC
    707
    Default opening dwg with current Civ3D through windows instead of outdated version
    Double clicked from window a Civ3D dwg that had been saved with 2021 but the file tried opened with 2018. Is there a way to get newest version to be default when double clicking a dwg in windows?
    Cairo - no, not Illinois
    4,817
    Default Re: opening dwg with current Civ3D through windows instead of outdated version
    uninstall all the others??
    or hardwire the .dwg filetype with the full path to 2021 (plus whatever arguments you need)
    9,771
    I know this is not what you want to hear, but open Civil 3D 2021 first, then drag+drop the DWG file onto the Command Line or the Title Bar.
    That is the only 100% guaranteed method.
    You can try the methods outlined online in various places, but none of them (in my experience) work as intended, all the time.
    I have a test PC with dozens of different versions of AutoCAD, AutoCAD Map, AutoCAD LT, Civil 3D, etc. and I would never rely on the O/S to pick the right version for me.
    Cheers
    Tallahassee, FL
    3,359
    By default AutoCAD Drawing Launcher is used when double-clicking a dwg file in File Explorer which should open it in the last AutoCAD dwg software application that was opened. It has nothing to do with what version it was saved in.
    DWG file type associativity in Windows https://knowledge.autodesk.com/suppo...n-Windows.html
    Autodesk recommends always opening DWGs from within the program but dragging a DWG file from Windows Explorer onto the correct AutoCAD program icon will work as well: https://knowledge.autodesk.com/suppo...D-Product.html
    Ph# (850)606-1516 Home Page
    Civil Engineering Moderator MHultgren's Avatar
    Central Iowa
    1,431
    ... dragging a DWG file from Windows Explorer onto the correct AutoCAD program icon will work as well: https://knowledge.autodesk.com/suppo...D-Product.html
    If you have the 2021 Icon pinned to your taskbar in Windows, then drag from File Mangler onto the icon, that will open the dwg in 2021. Just make sure the icon you have pinned has the correct profile switch set before ;pinning it if you use multiple profiles.
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
  1. Outdated subscription
    By jpearson in forum CAD Management - General
    Last Post: 2018-10-08, 11:37 AM
  2. 2016: upgrading to 2018 Civ3D
    By tim_newsome in forum AutoCAD Civil 3D - General
    Last Post: 2017-01-19, 08:09 PM
  3. Replies: 0
    Last Post: 2013-04-05, 11:39 AM
