Is there a method developed to make a pipe tag (or MEP Fabrication Pipework tag) with elevations (CL or BOP) read out as per mean sea level? Any help is greatly appreciated!
So my level says "2220'-6"... but my pipe elevations are saying "BOP 14'-0"... which isn't terrible, I can add a note that states that all pipe elevations are relative to floor elevation... yada yada...
Here's where it gets a little sticky.
I have a 3.5' recessed area with piping in there and leaving the area and tying into equipment in the upper level.
So this pipe is 14'-0" BOP from the recessed area, and 10'-6" BOP from the upper level. You can only have a pipe associated to one reference level. So I tag the pipe in the recessed area, it shows 14'-0" BOP. All good, right?
I tag the same pipe in the upper area, it, still says 14'-0" BOP. This is not so cool.
So short of putting a break in the pipe and assigning one part of the pipe to one level, the other part to the other level, I would like to be able to apply a mean sea level elevation to those tags. No fuss, no muss....
Don't get me started on BOP tags when you add insulation to pipes (especially MEP Fab Pipework). That's a whole other topic for another day.
