Thread: Multileader
    Wish List Administration
    2011-08
    4,581
    Default Re: Multileader
    Summary: Multileader Rotate to match to DView TWist
    Description: To use Multileaders in Civil 3D has always required purchasing software like Sincpac-C3D. With all the years this command has been around why hasn't this command been modified to work in the Civil 3D we already paid for yet? https://forums.autodesk.com/t5/civil-3d-forum/snap-mode-settings/m-p/6444054#M306975
    Product and Feature: AutoCAD Civil 3D - Other
    Submitted By: Tom Beauford on 08/29/2020
    Tallahassee, FL
    3,374
    Lisp patched together from others for drawing a Multileader whose Rotation matches the DView TWist angle for Civil drawings.
    ;| Modified code from danglar & Kent1Cooper
    https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/rotating-leader-to-current-view/m-p/6934473#M350902
    ^P(if(not C:MultileaderHoriz)(load "MultileaderHoriz.lsp"));MultileaderHoriz
    (load "MultileaderHoriz.lsp");MultileaderHoriz
    (defun c:zzr () (c:MultileaderHoriz)) ; Create Horizontal Multileader with Text aligned Horizontally |;
    (defun c:MultileaderHoriz (/ *error* snapang AT:UCSAngle ang ss name ldr pts23 base refang)
      (defun *error* (msg)
        (command-s "UCS" "World")
        (setvar "snapang" snapang)
    ;    (setvar "snapang" (- (getvar "viewtwist")))
        (and *AcadDoc* (vla-endundomark *AcadDoc*))
        (setvar 'CMDECHO 1)
        (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,")))
          (princ (strcat "\nError: " msg))
      (defun AT:UCSAngle (/) ; Return current UCS angle by Alan J. Thompson, 04.06.10
        ((lambda (x) (atan (cadr x) (car x))) (trans (getvar 'UCSXDIR) 0 (trans '(0. 0. 1.) 1 0 T) T))
      (vl-load-com)
      (vla-startundomark
        (cond (*AcadDoc*)
              ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
      (setvar 'CMDECHO 0)
      (setq snapang (getvar "snapang"))
     (command "UCS" "View")
     (setvar "snapang" (- snapang (AT:UCSAngle)))
    ; (setvar "snapang" 0.0)
     (command-s "MLEADER")
      (*error* nil)
    Ph# (850)606-1516 Home Page
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,483
    Changing the UCS to match the VIEW of the viewport works just fine without the need to purchase any add-ons. Although, SincPac may have additional features that assist with Civil 3D drafting.
    Tallahassee, FL
    3,374
    Don't own the SincPac software but the posted lisp does draw the Multileader with the UCS set to View and ensures it's set back to World that Civil 3D functions require. As annotative text, dimensions, and blocks align horizontally just like Civil 3D labels it sure would be nice if annotative Multileaders worked the same as they did.
