Thread: AutoCAD Lisp For Replacing Text With A Block
    2020-10
    Default AutoCAD Lisp For Replacing Text With A Block
    Hi All,
    I hope I am on the right forum.
    I have been looking for a lisp routine that will replace multiple text entities with a block.
    The block should be at the same insertion point as the text and the same rotation.
    I found similar threads online, but not quite the same thing.
    Does anyone have a routine to share?
    I am not able to write the routine myself, so I was looking for an existing one.
    Kind Regards,
    WayneSA
    Western Europe
    57
    Default Re: AutoCAD Lisp For Replacing Text With A Block
    You'll need to be more specific? Text and/or MText? What happens if the *Text is justified? Is the block static or dynamic? Does it have attributes? How do you want to select the *Text? Is the *Text on a single layer or Multiple layers?
    ROMANIA
    35
    Quote Originally Posted by waynekay24792565 View Post
    Hi All,
    Kind Regards,
    WayneSA
    Try this:
    ;;liviu_dova@yahoo.com
    (vl-load-com)
    (DEFUN C:REP-TXBK (/ *error* $Name bName EgEnt ENT lsBlN)
      (defun *error* (s)
        (or (wcmatch (strcase s) "*BREAK,*CANCEL*,*EXIT*") (prompt (strcat "\nError: " s)))
      ) ;;*error*
    ;List of block names
      (vlax-for
         itm
        (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
        (if (and
              (vlax-property-available-p itm "Name")
              (/= (substr (setq $Name (vla-get-name itm)) 1 1) "*")
          (setq lsBlN (cons $Name lsBlN))
      (if lsBlN
        (progn
    ;;Choose the block
          (while (not bName)
            (setq bName (getstring T "\nEnter block name or [?]: "))
            (cond
              ( (= bName "?")
                (textscr)
                (prompt "\nDefined blocks:")
                (foreach el lsBlN (prompt (strcat "\n" el)))
                (prompt "\nClick or Press any key to continue...")
                (vl-catch-all-apply (function grread) (list nil 14 0))
                (setq bName (graphscr))
              ( (= bName "")
                (setq bName nil)
              ( (and bName  (not (vl-position (strcase bName) (mapcar (function strcase) lsBlN))))
                (setq bName (prompt (strcat "\nCould not find block name \"" bName "\".")))
              (T nil)
    ;;Choose the text and replace it with the choosed block.
          (while  (and  (setq ENT (car (entsel "\nSelect the text to be replaced: ")))
                        (= (cdr (assoc 0 (setq EgEnt (entget ENT)))) "TEXT")
            (if (= (logand 4 (cdr (assoc 70 (entget (tblobjname "LAYER" (cdr (assoc 8 EgEnt))))))) 0) ;;Layer not locked
              (progn
                (entdel ENT)
                (entmake
                  (list
                    (quote (0 . "INSERT"))
                    (quote (100 . "AcDbEntity"))
                    (cons 67  (cdr (assoc 67  EgEnt)))
                    (cons 410 (cdr (assoc 410 EgEnt)))
                    (cons 8   (cdr (assoc 8   EgEnt)))
                    (quote (100 . "AcDbBlockReference"))
                    (cons 2 bName)
                    (cons 10 (cdr (assoc 10 EgEnt)))
                    (cons 50 (cdr (assoc 50 EgEnt)))
              (prompt "\nText is on a locked layer.")
        (prompt "\nNo block definitions in the drawing.")
    ) ;;REP-TXBK
    2020-10
    Hi, the routine runs initially but stalls at text selection. The text is single line text; justified at middle centre. Text is all on the same layer and unlocked. The block is just static. Thanks for commenting. Regards, Wayne.
    ROMANIA
    35
    Quote Originally Posted by waynesa View Post
    I checked the program for the middle center text justification and it works. Please attach a drawing (maximum rel. 2015) and the name of the block to be inserted.
  1. Replacing a title block
    By pdstro in forum AutoLISP
    Last Post: 2018-11-18, 05:28 AM
  2. Replacing blocks with a block with the same name
    Last Post: 2013-10-28, 12:22 PM
  3. Replacing Text
    By masonjur in forum Revit Architecture - General
    Last Post: 2006-08-28, 03:46 PM
  4. LISP for selecting block and replacing with another
    By ken_nofuente in forum AutoLISP
    Last Post: 2006-06-29, 04:53 PM
