Re: Move/Copy Corridor Regions
Summary: Ability to move or copy corridor regions to a duplicate baseline.
Description: Many times I start preliminary design with a simple assembly without much detail. I tend to start design with a very generic assembly for a full roadway and then set up right-hand and left-hand assemblies once more detail is added into the design. It would be nice to be able to either drag and drop or copy a region from baseline to baseline within the parameter tab. If the region is moved to a baseline with a different alignment, then the stationing would become blank, or the default beginning/end of the alignment; if moved/copied to a new baseline with the same alignment, the stationing would remain the same.
Product and Feature: AutoCAD Civil 3D - Corridor
Submitted By: Russell719599 on 10/13/2020
- You may not post replies
- You may not edit your posts
Forum Rules
