Thread: Taging problem
    2005-04
    Saintlouis Missouri
    529
    Default Taging problem
    I am trying to tag lighting in a rcp and it trying to tag the elements like a sink when the wall light is above. It is also trying to tag elements in the linked file. This has not happened before, so I am thinking someone in the office changed a setting but have no idea what that would be. Any thoughts? Thanks.
    2015-08
    199
    Default Re: Taging problem
    It is likely that plumbing fixtures was turned on in the plan for some reason, probably for sprinkler heads. It might be easier to just use the tag all command and select lighting so that all lights get tagged in the plan at once. Then you can shift the tags around afterwards if needed.
    2005-04
    Saintlouis Missouri
    529
    That is a good idea. It is not for me so I will pass along your answer. Thanks.
  1. interface problem after problem after problem
    By whatisrice in forum ACA General
    Last Post: 2009-08-12, 05:06 PM
  2. Taging and Comments
    By patric.bryntesson in forum NavisWorks - Wish List
    Last Post: 2008-12-20, 08:34 PM
  3. Taging a linked file?
    By ron.sanpedro in forum Revit Architecture - General
    Last Post: 2008-03-20, 10:14 PM
  4. Autodesk Building System 2006 auto Taging
    By 3d.140577 in forum AMEP General
    Last Post: 2008-02-11, 03:00 PM
  5. Taging Sweeps
    By ebtrad in forum Revit Architecture - General
    Last Post: 2007-10-04, 01:21 PM
